Seanalmet11
Mar 02, 2023Aspirant
Ac 600 slow to connnect
Just went from TP Link adapter to NG AC600. The TP link was an instant connection when booting but the NG takes up to 60 sec to connect to my wifi network. It's a good and fast connection when it c...
michaelkenward
Mar 03, 2023Guru - Experienced User
That would be the A6100. An ageing (2016) device that hasn't seen an update since 2016. It was designed well before the era of Windows 10, to support things like XP.
Are you using Netgear's software or whatever version of Windows you are on?
- Seanalmet11Mar 03, 2023AspirantNetgear software, windows 11 home edition
- michaelkenwardMar 03, 2023Guru - Experienced User
Seanalmet11 wrote:
Netgear software, windows 11 home editionI can't see Netgear updating to support that.
I may find time to see if I can get mine to work, but I moved on to newer WiFi for Windows a while back.
