BartN's avatar
BartN
AC1200 USB Wifi adapter - How to select wifi adapter ?
Hello, I installed the Netgear AC1200 Wifi USB adapter on my portable. How can I select that this adapter should be used en not the internal Wifi adapter ? Kr, Bart
  • plemans's avatar
    May 06, 2020
    which portable?
    if its a windows device, go to control panel---->network and sharing center---->change adapter settings------->select the one you don't want to use and right click-->disable
