johnmartinez17
Feb 05, 2022Aspirant
AC1200 USB Wifi Adapter
I have tried using the install CD to install the drivers and it just sits there. It never finishes. So, then I came to this website to try and download the drivers from this website. SAME ISSUE!!! ...
michaelkenward
Feb 06, 2022Guru - Experienced User
Do you mean you cannot download the files from the webs site?
Or does nothing happen when you try to run the download?
- johnmartinez17Feb 06, 2022AspirantYes, I can initiate the download process, but progress bar just sits there and does not move or complete the download process.
- plemansFeb 06, 2022Guru - Experienced User
Have you tried on a different device? If it isn't downloading it sounds like a device issue. I just tried to download them on my pc and it worked fine.
- michaelkenwardFeb 06, 2022Guru - Experienced User
My thought exactly.
Failure to download often signals problems at the user end.
I too retrieved the file with no problems,
Is this what you went for?
A6150 Software Version 1.0.0.5 (Windows) | Answer | NETGEAR Support
