johnmartinez17
Feb 05, 2022Aspirant
AC1200 USB Wifi Adapter
I have tried using the install CD to install the drivers and it just sits there. It never finishes. So, then I came to this website to try and download the drivers from this website. SAME ISSUE!!! ...
michaelkenward
Feb 06, 2022Guru - Experienced User
Do you mean you cannot download the files from the webs site?
Or does nothing happen when you try to run the download?
johnmartinez17
Feb 06, 2022Aspirant
Yes, I can initiate the download process, but progress bar just sits there and does not move or complete the download process.
- plemansFeb 06, 2022Guru - Experienced User
Have you tried on a different device? If it isn't downloading it sounds like a device issue. I just tried to download them on my pc and it worked fine.
- michaelkenwardFeb 06, 2022Guru - Experienced User
My thought exactly.
Failure to download often signals problems at the user end.
I too retrieved the file with no problems,
Is this what you went for?
A6150 Software Version 1.0.0.5 (Windows) | Answer | NETGEAR Support
- johnmartinez17Feb 06, 2022Aspirant
You are correct. It is my laptop that appears to be preventing the load to completed. Not sure if it's my ant-virus protection or my device all together. I will keep trying.
I was able to install AC1200 USB Wifi Adapter on a different laptop. Something on my current laptop is causing it to not install. It sits on the setup status and progress bar does not move. I disabled all my ant-virus softward and that did not help.
- michaelkenwardFeb 07, 2022Guru - Experienced User
That makes it hard to diagnose what is going on.
I assume that you have checked that you need the drivers. Windows may have some generic drivers that work.
Failing that, you may need to mess around in the Device Manager area in Windows. In particular, the USB controllers and the Network Adapters. Tell it to Show Hidden Devices and uninstall anything that looks like an old Netgear wifi adapter.
Wifi adapters
