savinus
Dec 05, 2022Aspirant
ac1200 wifi usb adapter A6150 slow
Hello, please I have ac1200 wifi usb adapter A6150 with a vodafone wifi 6 station ftth network on windows 10 pc i7 processor with 16 gb ram with stick on usb3 and on advanced I entered IEEE 802 11 a/...
Dec 06, 2022Guru - Experienced User
It doesn't matter how fast the vodafone is. The A6150 is going to be the bottleneck.
Its a AC1200 device with is 867mbps 5ghz and 300mbps 2.4ghz (they don't combine during usage).
It fastest link speed is going to be 867mbps over 5ghz and that's if you're right next to the router.
And as I said, that's link speed, not actual throughput. Throughput (actual speed) is 55-65% of what the link speed is.
So that maximum you *might* see (with zero interference, sitting right next to the router) is going to be around that 400-500mbps.
Again, that's with zero interference, sitting next to the router, and with nothing else that can cause issues.
Add some distance/obstructions/interference in and the hitting 270mbps is about what you can expect from that device because its a micro-adapter with small antenna in it.
You will not hit 1000+ mbps on that device or even close to it.
If you want to read more about wifi and why its overblown this is a good article.
https://www.duckware.com/tech/wifi-in-the-us.html
