savinus
Dec 05, 2022Aspirant
ac1200 wifi usb adapter A6150 slow
Hello, please I have ac1200 wifi usb adapter A6150 with a vodafone wifi 6 station ftth network on windows 10 pc i7 processor with 16 gb ram with stick on usb3 and on advanced I entered IEEE 802 11 a/...
michaelkenward
Dec 08, 2022Guru - Experienced User
savinus wrote:
Hello, the vodafone wifi 6 station should go to 1000 or 2000, I', only 3 meters from the wifi modem with no obstructions, maybe there's some error in my config? Thanks
Have you asked Vodafone what wifi speeds you can expect its router to deliver in the real world, rather than the fantasy land of marketing?
Vodafone has its own equivalent to this community:
Could be an other place to compare notes with fellow users.
TechDanne
May 31, 2023Aspirant
I only got 100/100 Mbit/s in my apartment. When I installed this dongle in Win 11 I got about 85/85 (okey speed) but now I only got 14/36. I have tested to change between AC and N but it doesn't make any difference. When I do ping and tracert I can't see any bottleneck to the Gateway and WAN. When I do the same test with my Smartphone in the same spot I get 63/80.
- michaelkenwardJun 01, 2023Guru - Experienced User
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.You could also add more details about the source of your wifi.
- TechDanneJun 01, 2023Aspirant
Sorry for doing search for existing threads about slow A6150 and not creating a new thread. I have solved my problem by changing to another USB socket. I get 95/90 in a benchmark. Have a pleasant day and I'm really sorry to bother you #. Bye bye.
