Ethanolbanua
Aug 24, 2022Follower
AC1900 A7000
Please help. My WIFI adapter (AC1900 A7000 USB Adapter) has been randomly disconnecting for a few seconds every minute or so. I followed this YouTube guide which made me turn off Something (RunSwUS...
michaelkenward
Aug 25, 2022Guru - Experienced User
Ethanolbanua wrote:
I followed this YouTube guide which made me turn off Something (RunSwUSB) and it has removed (Uncommon or Completely gone) this problem.
I have no idea what that means. Do you mean that you did something that fixed the problem with the adapter?
The problem now is that my power went out and it seemed to comeback a lot more than then (10 seconds of pausing every 30-50 seconds). I checked if the thing I turned off was off and it still was so I'm not sure how to fix this problem. Any fixes?
I can't even hazard a guess as to what that means. Power on what?
What problem are you trying to fix? The USB adapter? Something else?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. As it is, your issue is with a USB wifi adapter which is nothing like a router.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Adapters - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
