ElliotSterkel
Jan 23, 2020Follower
AC600 keeps losing connection
So I bought the AC600 adapter awhile ago, and for the first couple months of having it, it worked great. I was getting good connection in game and fast download speeds. But recently I had to go back ...
Jan 24, 2020Guru - Experienced User
I've seen repeated posts about this issue with the A6100. many times its because they got hot or the driver causes issues.
What you can do? try doing a clean install with driver only for the A6100.
If it doesn't work, I'd return/rma it through warrany if you're still within your warranty period.
there's a post here about the A6100. A6200, A6210. There's several different idea, driver installs, etc that you can read through and try if your warranty is expired.
