mged's avatar
mged
Follower
Jun 17, 2020
AC600 WiFi USB Adaptor
I recently purchased this wifi adaptor (retailed as AC600 802.11ac Dual Band Adaptor). Installation etc all went OK. Hooked up to my 5ghz wifi home network and all ok. However whenever I boot my pc I have to manually open Netgear Genie and select the connection, previously with my old 2.4ghz pci-e card it would connect automatically. I cannot see any method of getting the AC600 to do likewise. 'Connect automatically when in range' in Win 10 settings for my network is on. Anyone got any thoughts?
Thanks...
1 Reply
  • plemans's avatar
    Try uninstalling the driver and setup utility.
    Then reinstall it using the driver only. the "standalone" driver Then let windows handle the networking instead of the netgear genie.
