r1itter
Nov 08, 2024Aspirant
AC600 wireless adaptor
The wifi on my work laptop suddenly became disabled. There was no way to enable wifi without admin privileges but the laptop would not recognize admin login credentials. So I thought I could use a wi...
Nov 09, 2024Guru - Experienced User
If your work computer won't even let you re-enable wifi without admin privileges, it's doubtful it'll let you install software to the device. Maybe just call the IT department of where you work to have them re-enable wifi.
