devildog4
Sep 17, 2020Follower
AC600 won't connect to 5GHz
AC600 dual band adapter wont connect to 5GHz. Always connects @2.4 GHz.
Even when chosing 5GHz it will connect to the slower speed. Passwords are the same except for a number at the end. Could that be the issue?
How do I change the passsword(s), that should solve the issue?
Thx...
1 Reply
what router are you connecting to?
does it use a single ssid setup or are the ssid's for the 2.4ghz and 5ghz different?
