CorbinGallion
Jan 16, 2023Follower
AC7000 genie wont start
I downloaded the A7000_V1.0.0.15_Windows file to install the genie so the genie will give me the program yeah well I installed it and waited for the genie to open so i could start the setup and it wa...
Jan 16, 2023Guru - Experienced User
I usually use the stand alone driver and just let windows manage the wireless connection setup. Have you tried that?
- michaelkenwardJan 19, 2023Guru - Experienced User
I'm guessing here, but I think that plemans is referring to the "SA" program mentioned in the release notes:
A7000 Software Version 1.0.0.15 (Windows) | Answer | NETGEAR Support
You will find that the zip file contains two exe files.
Try A7000_Windows_Standalone_V1.0.0.15.exe
Or see if the native drivers in Windows will work.
