BedrosN
Jan 11, 2021Aspirant
Adapter wont work (A7000 AC1900 Netgear Nighthawk wifi USB Adapter)
I recently moved into a new home and i have a PC that doesnt have a built-in wifi adapter. At my old home I had plugged in the AC1900 Nighthawk wifi adapter and it was able to pick up and connect to ...
michaelkenward
Jan 12, 2021Guru - Experienced User
BedrosN wrote:
when i try to connect to my wifi network it keeps saying " No Internet, Secured."
That may be down to Windows trying to protect you from what it sees as a dangerous network.
How are you trying to connect to the wifi? Using Windows "Network & Internet" settings.
- BedrosNJan 13, 2021Aspirant
I've tried both ways. Using the network and internet way and also the NETGEAR Genie. Both ways end up with it saying " No internet, secured"
