patmac7a7
Nov 11, 2023Aspirant
Before I Install AC1200 Question
Hi, Before installing my AC1200 USB Wireless adapter, do I need to, and if so, how do I go about disabling my old intermittent original wireless adapter in my laptop? My original adapter sometimes ...
michaelkenward
Nov 12, 2023Guru - Experienced User
You shouldn't have to do that.
Windows (which version do you have?) should be capable of telling them apart.
- plemansNov 12, 2023Guru - Experienced User
You can also go in windows and right click on the adapter and "disable" it
- michaelkenwardNov 12, 2023Guru - Experienced User
That would be Network Adapters in Device Manager? The problem there is that patmac7a7 says:
"My original adapter sometimes does not show up in Device Manager."
If it isn't visible, one way to get around that might be to look for Hidden Devices in Device Manager.
Then Uninstall Device. That could bring it back to life and allow Disable.
Bit before going to any effort, just see what happens when it is installed.
By the way, AC1200 isn't the device model. That will be something like A6150 or A6120. AC1200 is the wifi speed specification.
- patmac7a7Nov 13, 2023Aspirant
Thank you everyone for your help. It installed fine, but now I have a quick question regarding the values Under the advanced tab of the device.
I'm having not so good (-75db) reception with it. Anything I can tweak the above values to increase my reception quality?
Thanks
