GlitchedSolaria
Aug 11, 2024Follower
Bluetooth headphone audio cutting out
I've been having some problems with my WIFI adapter - the ASUS LAN WIFI-AP ring antenna - and it was making my computer really slow and have trouble connecting to any WIFI, which I found was because ...
Oct 04, 2024Guru - Experienced User
Any progress on this?
GlitchedSolaria wrote:
I've been having some problems with my WIFI adapter - the ASUS LAN WIFI-AP ring antenna - and it was making my computer really slow and have trouble connecting to any WIFI, which I found was because the cord that connected it to my computer had broke. So I just went out and bought the NightHawk AX1800 WIFI 6 USB 3.0 Adapter, and it has been working great for my WIFI problem - but it has also been causing some problems with my Bluetooth headphones. Before I switched out my WIFI adapter, my headphones - the Sennheiser MOMENTUM 4 - have had no problems connecting to my computer or holding a connection (and each time they'd connect it say "connected music, voice"). But after I plugged in the adapter, they have been cutting out excessively, hardly playing any audio from Spotify, YouTube, or really anything (And now, each time I've actually been able to connect them, it only says either "connected music" or "connected voice"). I can't test if the problem is with the adapter cause my old one broke, but I'm pretty sure that's the problem. Any help would be great.
