Rlcotejr
Apr 11, 2020Follower
Can’t locate QoS
Hello, I’m having a hard time locating the enable “QoS” option. In our advanced settings of Genie under “Setup”, QoS is not an option. Please advise.
michaelkenward
Apr 14, 2020Guru - Experienced User
Is this on the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway?
Or did you just click the first thing that popped up when you wrote your message?
QoS is a router thing. The A7000 is a WiFi USB Adapter
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware and drivers for your device.
Look for the model number on the label on the device.
