SteveVG
Dec 25, 2020Aspirant
Can I use my Windows 10 desktop as a hotspot using WNDA31100v2 USB adapter
Can I use my Windows 10 desktop as a hotspot using Netgear WNDA31100v2 USB adapter? My desktop is attached to the internet by an ethernet cable. There is no WiFi available and I would like to have...
Dec 26, 2020Guru - Experienced User
i think windows 10 has it built in.
How to use your Windows 10 PC as a mobile hotspot » OnMSFT.com
- SteveVGJan 09, 2021Aspirant
If your desktop does not have a wifi adapter, Windows 10 can't set up your computer as a hotspot to share your internet connection. The question I had posted was asking if the Netgear WNDA3100 v2 would be able to broadcast a wifi signal and make your desktop computer a hotspot.
This Netgear USB device allows your desktop computer to receive a wifi signal to connect to the internet using wifi.
