Retired_Member
Jul 31, 2022Cannot check firmware updates
Im trying to check A7000 firmware updates with genie software, it advances to 20%, and stays there forever ?
- Retired_MemberJul 31, 2022
But you didnt understand that i have been doing what you suggested in first place ?
Anyways, if this usb stick is allready abandoned by netgear, i wont bother anymore 🙂
Ty you for the suggestions and for replying.
Retired_Member
Jul 31, 2022Im not looking software, your link is for genie software 🙂 Within genie software you should be able to update firmware..
I dont see any other way to update usb stick since it does not have its own web frontend or ui...
michaelkenward
Jul 31, 2022Guru - Experienced User
Did you read my message?
The way to update the usb stick is to download the software and run the program it delivers.
Try reading this again:
A7000 Software Version 1.0.0.15 (Windows) | Answer | NETGEAR Support
To Install:
Using the Download Link below, download and extract the new software to a convenient place such as your desktop.
Download Link:
http://www.downloads.netgear.com/files/GDC/A7000/A7000_V1.0.0.15_Windows.zip
In other words, it is the same process as just about anything you need to update on a computer.
If you need the Mac version, that is there too.
