Anonymous
Jul 31, 2022Cannot check firmware updates
Im trying to check A7000 firmware updates with genie software, it advances to 20%, and stays there forever ?
- AnonymousJul 31, 2022
But you didnt understand that i have been doing what you suggested in first place ?
Anyways, if this usb stick is allready abandoned by netgear, i wont bother anymore 🙂
Ty you for the suggestions and for replying.
Anonymous
Jul 31, 2022Well, did you read my first message?
michaelkenward
Jul 31, 2022Guru - Experienced User
Yes.
I explained how to achieve what you need, an update for your USB adapter.
Feel free to keep hammering away with the "genie". Life, and Netgear, have moved on since then.
Maybe you don't really t want to update the USB adapter. But I can't think of any other use for the "genie".
- michaelkenwardJul 31, 2022Guru - Experienced User
Retired_Member wrote:
But you didn't understand that i have been doing what you suggested in first place ?
Where did you say that?
Anyways, if this usb stick is allready abandoned by netgear, i wont bother anymore 🙂Who said that?
