Donbrad
May 04, 2022Follower
Can't locate NETGEAR_EXT Wi Fi on my phone.
Trying to set up a Wi Fi Mesh Extender which uses Nighthawk. It asks me to connect the NETGEAR_EXT Wi fi to my mobile phone. This Wi Fi doesn't appear in a search and I've tried to put it in manually. Tells me that it cannot find that NETGEAR_EXTR WI FI. Frustrating. What am I doing wrong?
Is that just on the phone? Can other devices see the SSID?
What tells you that it cannot find that NETGEAR_EXT?
What Netgear device are we talking about here? NETGEAR_EXT suggests a wifi extender.
You have put your message in the section for WiFi Adapters. That isn't likely to be involved in any communication with your phone.
What extender do you have?
That'd be nice to know as there's many "mesh" models that don't use a separate ssid but the same as the router.And if they're setup using wps, they'll automatically use that same ssid.
Its designed so devices can choose to roam between extender/router as needed and without needing the input of the user.
