Dresel
Sep 29, 2019Follower
compatibility macos catalina
I just bought the Nighthawk AC1900 Wifi USB adapter. Will it work with Macos Catalina?
- Oct 09, 2019
After Searching I found this tool, and it get it to work on Catalina. Hope it helps atleast temporarily until Netgear releases the fix
michaelkenward
Oct 03, 2019Guru - Experienced User
What's that?
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
- AnydCatalinaUsrOct 07, 2019Tutor
michaelkenward wrote:
Dresel wrote:Will it work with Macos Catalina?
What's that?
It's the macOS new operating system. The update was released today the 7th and it broke the use of everyones A7000 USB WiFi Adapter.
- glamdrainOct 08, 2019Guide
I tryed to install the driver listed from the error shown it is trying to put it in the wrong place, so no it is not compatible with catalina
- michaelkenwardOct 08, 2019Guru - Experienced User
If Apple has broken something, then let them know as well as Netgear.
There is a good chance that other makers of USB Adapter's have fallen victim to the same bug.
