Dresel
Sep 29, 2019Follower
compatibility macos catalina
I just bought the Nighthawk AC1900 Wifi USB adapter. Will it work with Macos Catalina?
- Oct 09, 2019
After Searching I found this tool, and it get it to work on Catalina. Hope it helps atleast temporarily until Netgear releases the fix
Squishy4
Oct 09, 2019Aspirant
32bit programs no longer work on maxis Catalina.
glamdrain
Oct 09, 2019Guide
Your right,
After watching the video posted in the previous post the two things needed are
1. since the root file is now read only and there is now a Stand alone partition for software, the software will now need to point the install to this standalone partition.
2. the install will have to be a 64bt install.
I spoke to somone at Netgear and was told they are working on installs for mojave and Catalina. But of corse there is no telling as to how long it will be before it would be dropped for the public.
- amakOct 09, 2019Initiate
- adairluscherDec 20, 2019Aspirant
I will check that out, thank you!
- adairluscherDec 22, 2019Aspirant
I installed it today and it works great. Thank you for your recommendation, it is much appreciated.
- devopsterusDec 29, 2019Aspirant
It's really too bad, I'll probably end up returning the product to Best Buy. Also, it's misleading to state "MacOS 10.8.3 or later" on the box.
The OSS WIFI solution posted here requires that you disable System Integrity Protection (SIP) which is a Mac OS security measure designed to protect against malware.
https://support.apple.com/en-us/HT204899
Unless you know the full ramifications, it's not a good idea to mess around with this.
So to update, looks like recent releases no longer require SIP to be disabled, which is great news.
The driver seems to work with my mobile tether, it is not working on Starbucks WIFI right now.
