Dresel
Sep 29, 2019Follower
compatibility macos catalina
I just bought the Nighthawk AC1900 Wifi USB adapter. Will it work with Macos Catalina?
- Oct 09, 2019
After Searching I found this tool, and it get it to work on Catalina. Hope it helps atleast temporarily until Netgear releases the fix
AnydCatalinaUsr
Oct 08, 2019Tutor
michaelkenward wrote:If Apple has broken something, then let them know as well as Netgear.
There is a good chance that other makers of USB Adapter's have fallen victim to the same bug.
It is not a bug.
Apple has changed the way applications are installed ontop of the operating system by introducing a read-only system volume.
https://developer.apple.com/videos/play/wwdc2019/710/
Here is a link explainging what and why they changed it.
Blanca_O
Oct 17, 2019NETGEAR Employee Retired
Hi, All,
For now, the A7000 MacOS software cannot support MacOS 10.15 (Catalina). Engineering team are working on a new software to support MacOS 10.15. We expect to support it first quarter of 2020.
Blanca
Community Team
