Dresel
Sep 29, 2019Follower
compatibility macos catalina
I just bought the Nighthawk AC1900 Wifi USB adapter. Will it work with Macos Catalina?
- Oct 09, 2019
After Searching I found this tool, and it get it to work on Catalina. Hope it helps atleast temporarily until Netgear releases the fix
Blanca_O
Oct 17, 2019NETGEAR Employee Retired
Hi, All,
For now, the A7000 MacOS software cannot support MacOS 10.15 (Catalina). Engineering team are working on a new software to support MacOS 10.15. We expect to support it first quarter of 2020.
Blanca
Community Team
jasonphorne
Nov 27, 2019Initiate
So, should everyone just be all right with not having network access for a few months? You should really post a fix immediately.
- MiljenkoHorvatNov 29, 2019Aspirant
Yes, this is just crazy - to not support Catalina with so much time to prepare for it is just lazy. And Netgear is not a cheap product - it is a Premium priced stuff where this should be inexcusable.
Last time I bought any of that hardware.
