Dresel
Sep 29, 2019Follower
compatibility macos catalina
I just bought the Nighthawk AC1900 Wifi USB adapter. Will it work with Macos Catalina?
- Oct 09, 2019
After Searching I found this tool, and it get it to work on Catalina. Hope it helps atleast temporarily until Netgear releases the fix
devopsterus
Dec 29, 2019Aspirant
The OSS WIFI solution posted here requires that you disable System Integrity Protection (SIP) which is a Mac OS security measure designed to protect against malware.
https://support.apple.com/en-us/HT204899
Unless you know the full ramifications, it's not a good idea to mess around with this.
devopsterus
So to update, looks like recent releases no longer require SIP to be disabled, which is great news.
The driver seems to work with my mobile tether, it is not working on Starbucks WIFI right now.
