thx4service
Jun 15, 2021Aspirant
connection issue
Hi
Suddenly Wps doesn't light up
I kept pressing the button, but it didn't work.
I dont know what to do..
You have the A6210 adapter?
You can always installing/connect manually instead of using wps.
The guide goes over it.
- thx4serviceAspirantI've been using it for about a year and it suddenly doesn't work.
Ok, so if the wps button doesn't work, try the manual method.
