thx4service
Jun 15, 2021Aspirant
connection issue
Hi Suddenly Wps doesn't light up I kept pressing the button, but it didn't work. I dont know what to do..
thx4service
Manual method? How can i do ??
Jun 15, 2021Guru - Experienced User
The support page I linked to prior?
It has the manual/guides that go over that.
- thx4serviceJun 15, 2021AspirantOh thx Ill try it
oh god finally im connect wifi
but pop up the new problem...
my conncection state is very unstablei looked at this link and try
https://kb.netgear.com/23352/A6200-A6210-WNDA3100v2-wireless-adapter-intermittently-disconnectsbut It hasn't been solved
- plemansJun 15, 2021Guru - Experienced User
Saying your connection is unstable doesn't say much.
What is your link speed?
what is your actual tested speed?
how far from the router is the adapter?
Whats between the adapter and the router (what materials)?
Whats actually happening. Saying its unstable can mean many different things- thx4serviceJun 15, 2021Aspirant
oh i mean frequently disconnected
Whats between the adapter and the router (what materials)? ARE ALL FINE... :(
I used it for a year without a problem
Is it possible that the device is old?
Thank you always for your reply.
