Jtully2048
Mar 04, 2020Tutor
Connection issues with FioS G3100
Pulling my hair out trying to figure out what is causing the issue here. We recently upgraded to the FiOS G3100 Gateway router and I've been able to connect my A7000 directly to the router. No...
tominbalt
May 30, 2020Initiate
In case this helps anyone:
I jus received the same g3100, and have the same connection issues with my A7000. However, when I configured the router, I turned on guest network as well. In the netgear genie app, it shows 3 access points - the main one twice and the guest one. Looking at the details, the main one has an 'AC' and an 'N' access point, and the guest is 'N'. I cannot connect to either of the main ones. Strangely (or maybe not), if I try to connect to the main 'N' one, it uses the 'AC' anyway - and it fails with the same issue (No Internet). HOWEVER, I can connect to the guest network. Of course, this is not ideal as I can't network with other devices in the house, but this is a temporary fix until the issue is fixed.
ryanmclaff
Jul 18, 2020Aspirant
I tried the connecting to the guest method but it didn't work for me. Did you change any other settings prior to connecting?
