Jtully2048
Mar 04, 2020Tutor
Connection issues with FioS G3100
Pulling my hair out trying to figure out what is causing the issue here. We recently upgraded to the FiOS G3100 Gateway router and I've been able to connect my A7000 directly to the router. No...
ilike0000
Aug 16, 2020Tutor
Issue is the 5.0Ghz connection. Once I disabled this on the router it started to work fine. Though 2.4Ghz is slower (kinda...ish) it has better range anyway. Something I can deal with until Verizon fixes this.
ClearCut
Aug 16, 2020Aspirant
On which router did you disable the 5Ghz? The GS3100 of Verizon's, or the Netgear?
- ilike0000Aug 16, 2020TutorOn the router. Log into the admin portal. By default it should be myfiosgateway.com or 192.168.1.1
Go into connections. Select a device that's connected to the network. Hit device details. Look for bridge. Select 5Ghz and disable it.
