Jtully2048
Mar 04, 2020Tutor
Connection issues with FioS G3100
Pulling my hair out trying to figure out what is causing the issue here. We recently upgraded to the FiOS G3100 Gateway router and I've been able to connect my A7000 directly to the router. No...
jose969
Oct 15, 2020Aspirant
Was there ever a fix for this issue from Netgear? I’m not shutting down a feature that I use. There should be another fix for this.
- ilike0000Dec 07, 2020Tutor
Yeah the only other solution is to go to your device manager, selecting your adaptor and not allowing 802.11.ac, so manually setting it to 802.11n. This would make only your device using this adopter to not be on 5Ghz.
- extender_man_12Dec 07, 2020Aspirant
Well, so the weird part is that I found that other post about the A7000 series and followed those steps to disable 5GHz on my G3100 but the issue still persists even after power cycling the EX6110 after inputting the correct settings. VZW support wanted me to buy their Samsung range extender which I definitely don't want.
Try changing your adopter settings to only use 802.11n
