hungry
Apr 02, 2019Aspirant
Connection Issues with Wifi USB Adapter Model A7000
Need to connect adapter to acer chromebook. Does not have a cd driver.
hungry
Apr 03, 2019Aspirant
Thank you. Could I download the Microsoft onto the acer chromebook then run it?
Apr 03, 2019Guru - Experienced User
It is potentially possible to do. However, if you need to ask if it can be done, I doubt you'd be able to do so as it takes a fairly tech savvy person to get it running. Not trying to be mean but its complex and adds to potential to brick your device.
- michaelkenwardApr 04, 2019Guru - Experienced User
