SFSBTJ
Dec 15, 2019Aspirant
Connectivity issues with A7000
So a few months ago I started having problems with my netgear a6210 wifi adapter. It started to receive reduced signal strength and constantly saying that I was conected but no internet was avalible....
Tom444
Dec 15, 2019Apprentice
Think you have done it all, like I have....
Have your tried to remove the cable out of the issue, plug the device into the computer directly?
Seen a couple of posts on faulty docking stations.Didn't fix my issues.
As for Typo's, spell check doesn't work on this site *Shrug*
- SFSBTJDec 16, 2019Aspirant
I uninstalled all the drivers and used a program called driver booster to clean all the old plug in device files offf of my PC and just shut down my PC for the night. This afternoon affteer work, I reinstalled the newest drivers and i've been able to maintain a steady connection since. I had to disable the switchUSB service again but so far so good. fngers crossed.
- Tom444Jan 18, 2020Apprentice
I gave up just bought an EdiMax for $25, rock solid, no issues.
Yes they do burn out after 6-9 months, but they just work out of the box.
Local store still have 10 left, so I might just stock up on them each visit.
Never going to trust Netgear again in my purchases.
