daboywonder2002
Jun 23, 2021Aspirant
Desktop says turn on wirelelss capability
Hello I need help. My wifi adapter is failing. Right now i'm on network connections and the Wifi adapter shows but its not connected. You hit diagnose and it says turn on wireless capability. But it'...
michaelkenward
Jun 24, 2021Guru - Experienced User
daboywonder2002 wrote:
Hello I need help. My wifi adapter is failing. Right now i'm on network connections and the Wifi adapter shows but its not connected. You hit diagnose and it says turn on wireless capability. But it's a desktop.
Windows? Mac? OS Version
EVen at the bottom right where it shows network and internet settings and under it you see wifi, airplane mode. right click on wifi and hit settings. Click on to turn wifi. But at the bottom right it still says wifi turned off.
Is that (top right here) Network and Internet Settings? Is there anything there in Show Available Networks?
Have you run the "Troubleshoot Problems" wizard?
What do you see here:
Control Panel\Network and Internet\Network Connections
- daboywonder2002Jun 24, 2021Aspirant
- michaelkenwardJun 25, 2021Guru - Experienced User
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay. (Look for the Browse button at the bottom of the text window.)
- michaelkenwardJun 26, 2021Guru - Experienced User
To me that suggests that your USB adapter is recognised and ready to go.
What happens when you "Right click" the icon?
Like this:
USB adapter dropdown
Does the Connect link get you anywhere? Here it brings up a set of available SSIDs.
By the way Alt+Print Screen is invaluable when trying to get screen shots.
It's hard to attach screenshots and photos. let me try to zip it
