CCSBCty
Sep 20, 2020Follower
Do I need an upgrade for WNDA3100?
I am not a gamer, but see new versions of WNDA3100, do I need to purchase newer versions or dowload upgraded firmware and software? Pretty much a novice, suggestions appreciated.
Sep 21, 2020Guru - Experienced User
It all depends on what you're using it for and if its meeting your needs. As well as what your internet/router capabilities are.
If its working, doesn't stutter, lag, cause issues, then I wouldn't worry about it.
As well as if you only have a single band router, whats the poing of upgrading to a dual band adapter.
but if your wanting faster connections, have a router capable of it, then it isn't a bad idea and they're not to expensive.
