RobSFreundlich
Feb 11, 2022Aspirant
Does the A6100 support Miracast?
I bought the A6100 because I was looking for a Wifi adapter that would let me use Samsung Dex over Wifi. But now that I've got it installed, my phone still can't see my PC. When I go to Settings -> S...
michaelkenward
Feb 12, 2022Guru - Experienced User
RobSFreundlich wrote:
I bought the A6100 because I was looking for a Wifi adapter that would let me use Samsung Dex over Wifi. But now that I've got it installed, my phone still can't see my PC. When I go to Settings -> System -> Projecting to this PC, I get the "This PC doesn't support Miracast" message.
Did you try this on your search for information?
Search - NETGEAR Communities – miracast
A long running saga.
RobSFreundlich
Feb 13, 2022Aspirant
michaelkenward wrote:Did you try this on your search for information?
I did. But all of the results were several years old, and none mentioned this adapter specifically. So I was hoping that perhaps there was newer information, specifically about this adapter.
