non-techClaire
Aug 10, 2017Aspirant
eMachines T5082 not wifi capable. I need to connect to a wireless router
I have an old emachines T5082 with Windows Vista Home basic. It has 160Gb hard drive and 512MB ddram and an Intel Pentium 4 Processor 631. I have a Netgear 93 router which currently connects my remain...
- Aug 25, 2017
Thanks. My Acer machines with Windows 7 both crashed catastrophically and so that problem is resolved (yuck). I will open a new threaad since my new problem is with different systems.
JamesGL
Aug 13, 2017NETGEAR Employee Retired
Hi non-techClaire,
You may check this USB adapters. It will work with Windows 7 OS.
http://www.netgear.com/home/products/networking/wifi-adapters/
JamesGL
Aug 24, 2017NETGEAR Employee Retired
Hi non-techClaire,
If you install the adapter on a different computer, will it work?
