mallyl
Nov 19, 2020Follower
Extending wireless WiFi to garage which is 25 m away from house
Will the plp 1000 pow3rline 1000 + extra outlet be adequate to give me wireless WiFi in the garage and would I need a router in the garage .
michaelkenward
Nov 21, 2020Guru - Experienced User
mallyl wrote:
...and would I need a router in the garage .
No.
Powerline Ethernet is really just a bit of wire between your existing router and the garage. You can then plug a wired Ethernet device into the plug, at the same time you can also use the wifi from the plug.
