smithave's avatar
smithave
External wifi card
January 22, 2022
I want to connect my HP PC to my Visio TV. My computer does not have a wifi card. Microsoft has a utility that will connect my PC to my TV if I can connect the PC and TV to the same wifi network. I am told that I need an external wifi card for PC with a USB connector to do that. Does Netgear have such a piece of hardware that will allow me to view computer programs, music, etc on my TV? If so, what's it called and what is the cost?
Thanks for your help.
Ray
[email protected]
  • plemans's avatar
    what visio tv is it? is it a smart tv?
    Some computers could screen share but i haven't found it that reliable.
    You could try something simple like putting plex on your computer and tv.
    • smithave's avatar
      smithave
      The TV is a smart TV. It is connected to WiFi. Is what I need called an EXTERNAL WIFI CARD or a USB WIFI ADAPTOR?
      • michaelkenward's avatar
        michaelkenward
        What are you trying to do?
        Connect a PC to the TV by wifi?
        And what do you want that connection to do? It takes more than a connection to view computer programs, music, etc on a TV. Yiur TV  has to have the software needed to make the connection and play the files.
        You say "Microsoft has a utility that will connect my PC to my TV". What would that be?
        As plemans says,  screen sharing is not reliable. It is also a pig to set up in my experience.
        I don't know what you mean by EXTERNAL WIFI CARD. Everything I can find suggests that it is the same thing as a USB wifi adapter. After all this "external card" has to connect to the PC some how. That usually means USB.
        The normal way t connect a TV and a PC is through a router. You can then use either wifi or wired Ethernet (LAN) to make the connection. In my case, because the TV doesn't move around the place I prefer LAN because it is easier to set up and less liable to fall over.
        A good way of doing this is with Powerline Ethernet. This turns the mains circuit into a LAN link.
