smithave
Jan 22, 2022Aspirant
External wifi card
January 22, 2022 I want to connect my HP PC to my Visio TV. My computer does not have a wifi card. Microsoft has a utility that will connect my PC to my TV if I can connect the PC and TV to the s...
smithave
The TV is a smart TV. It is connected to WiFi. Is what I need called an EXTERNAL WIFI CARD or a USB WIFI ADAPTOR?
Jan 23, 2022Guru - Experienced User
that isn't necessarily going to work.
If you're trying to get videos/photos from a laptop to your tv, you could install a media server like Plex or Emby to your laptop and the app on your tv. Tends to be a bit more reliable than try to rig adapters that might not work
