smithave
Jan 22, 2022Aspirant
External wifi card
January 22, 2022 I want to connect my HP PC to my Visio TV. My computer does not have a wifi card. Microsoft has a utility that will connect my PC to my TV if I can connect the PC and TV to the s...
smithave
Jan 31, 2022Aspirant
Thanks for your response. I am not electronically savy so I don't understand some of the terms y'all use.
Here's where I am. I bought a Netgear AC100 Wifi USB adaptor to provide wifi capability to my 10 year old computer--no internal wifi card. A Netgear tech--after hours of back-and forth--could not get the computer to link to my Vizio smart TV. I get a message on my computer that it does have "miracast" capability. The Netgear tech said the same thing. I tried to download Miracast from thier site. Got a messagethat said I could not do so--not compatible.
I went to Google Chrome and tried the CAST option--that didn't work.
I treid the Microsoft Action Center option--PROJECT, CONNECT, etc.--that didn't work.
The TV is linked to a wifi network. The computer says that it is linked to same wifi network. What do I need to do to link the TV to the PC desktop wirelessly so that what I see on the computer can be seen on the TV? (The two devices are too far apart to link with a cable.)
Thanks so much for your help. Sorry to be so uninformed.
Ray Strobo
smithave@aol.com
michaelkenward
Jan 31, 2022Guru - Experienced User
I can't find any Netgear USB adapter that is "AC100". That is not a model number. It is a wifi speed. There could be a buncg of AC100 devices. But that doesn't exist either. There is an AC1900 USB adapter, model number A7000. And the A6150 is AC1200.
I'm not sure that a USB adapter on its own can connect to a Smart TV.
The adapter is there to connect your PC to the wifi from your router. The Smart TV also connects to the wifi from the router. Then you need something extra so that the two things can see each other on the network.
So there is not TV to PC connection. As plemans said earlier, you need something else to do that.
How to Connect Laptop to VIZIO Smart TV Wirelessly – PC Webopaedia
- smithaveFeb 01, 2022Aspirant
February 1, 2022
I tried the Vizio connection above--wouldn't work--said my PC was not compatible with "Miracast". Ran a Direct X diagnostic tool. Was told that my DRIVER MODEL WDDM had to be 1.3 or higher for Miracast to work on my PC. (That's all I know about what I did--just followed instructions--don't know what any of it means.) My value was 1.1 so I assume that is why I cannot project my PC to my TV. Is there any way around this situation? I still would like to project my PC to my TV. Thanks so much for your help.
From an earlier reply: my Netgear device is an AC1200 WIFI USB ADAPTOR USB 2.0 DUAL BAND
- michaelkenwardFeb 01, 2022Guru - Experienced User
Not one that is easily dealt with in a community for Netgear hardware. It doesn't make the sort of device that you need.
You need to ask for help from someone who understand your PC and can advise on what you can add to it.
And from my earlier reply:
That is not a model number. It is a wifi speed.There are two USB adapters with AC1200 WIFI,the A6150 and A6210. But that will not make any difference.
It's a Model A6150. Thanks so much for your help. I really appreciate it.
