SmithRN
Oct 26, 2021Aspirant
Failure to Detect Adapter
Windows 10 The adapter worked on the PC. I inadvertantly selected the Netgear software in Control Panel when I intended to uninstall the software above Netgear. I didn't catch it in time to stop...
- Oct 29, 2021
The number of updates for this device was nearing double figures at the last count:
WNA3100M Software Version 1.2.0.9 | Answer | NETGEAR Support – undefined
This is one of several FAQs that might be worth reading:
SmithRN
Oct 28, 2021Aspirant
That didn't work. I found the adapter in Device Manager and uninstalled it, uninstalled the software, restarted the computer and then re-installed the software. Same result.
The entry in Device Manager indicated that adapter was not fully installed. One of the windows showed an error code 10. This is what the NetGear site says about the error code.
Causes for Code 10:
- IRQ conflict
- Adapter not plugged in properly
- Wrong/Incorrect driver installed
I'm using the original CD so I would expect the driver to be correct. It's hard to plug the adapter in wrong. So how do I check for an IRQ conflict and how do I fix it if there is a conflict?
Any other suggestions will be most appreciated.
michaelkenward
Oct 29, 2021Guru - Experienced User
I very much doubt that the CD has the latest drivers etc. Is there any reason why you can't check the support pages for your adapter?
