ChristianDenos
Jun 23, 2021Aspirant
frequent brief disconnects and speed bottleneck on A7000 nighthawk adapter
Every other minute or so I lose connection for a few seconds. Thought it might have to do with the old internet cables going into my apartment so I had xfinity come out and replace them. still had is...
ChristianDenos
Jun 24, 2021Aspirant
Yes megs means mbps.
My phone was connected to the same network.
I used xfinity speed test for both my computer and phone.
The main issue is the frequent disconnects. it makes competitive gaming virtually impossible when those 2 second disconnects means death in real time gaming.
Before upgrading my internet, 275mbps was fine for me. But that just created a seperated bottleneck issue which is quite frustrating when im paying for more speed and not getting it and also seeing others posting their 600+mbps speed with this adapter.
I understand ethernet is the best choice which would most likely solve my problems. But running the cable is unrealistic in my situation of where im living. I paid for this adapter because its the best on the market and i want what it is advertised to do yet i've run into 1 major and 1 minor issue. I'm looking for answers to them, not suggestions of using different equipment of which i've already mentioned would "on paper" be the better option but it just isnt for me.
Apologies for the frustration. This has just been an ongoing issue and ive spent quite a bit of time attempting to solve with no success.
bagg1o
Jun 24, 2021Guide
ChristianDenos many here had similar issues with this adapter, at least on modern setups, it have outdated software that is probbly not going to be updated any soon, but if your setup is not that new it will not hit you probably.
But, even if it had up to date software, getting stable speeds above 300Mbps on wireless means you'd need to basically stand near the router in most cases. This is my favourite page I show to people who wants to understand why they do not get speeds they want: http://mcsindex.com/ - it will show you how many modern technologies needs to be employeed for these speeds, like spatial streams, encodings or short GI "tricks" that need to be supported by both router and adapter - and all of those streams need to have good connection, also many of these technologies need better connection stability as you progress through them.
This is rarely told by marketers - but WiFi is not for speed, as already mentioned by michael. This is the reason I never bought internet above 300Mbps even though >1Gbps is easily achievable these days - because I don't want cables laying around and it's not feasible to get above this speed in most cases on wireless and to keep it anywhere stable. In practice, these kind of speeds are either for multiple simultaneous wireless users at home, or for wired connections.
- ChristianDenosJun 24, 2021Aspirant
bagg1o Ill have to check out that link you sent about internet speed. Though i dont understand how netgear can advertise 1.9gbps with this adapter when its supposedly not possible. I've never seen people get more than 600mbps with this adapter. Also, if im getting 600+mbps on my phone, why cant i get that with my adapter advertised to go 3 times that speed?
About a year ago i upgraded every component of my computer which is about a 1000 usd build which was right before the gpu crisis. so the bottleneck is very unlikely coming from anything else other than the adapter or potentially windows 10 itself.
Again, the main issue is not the speed bottleneck. It is the disconnects every other minute for 2-5 seconds. I've implemented solutions mentioned on previous posts here and youtube videos of people experiencing this same issue but to no success. Such as disabling RunSwUSB service and disabling 2.4ghz channel to prevent the channel swapping. Im really hoping someone can explain to me how to fix it or why those solutions are not working for me.
- michaelkenwardJun 24, 2021Guru - Experienced User
If this is a "home rolled" PC, was it a new motherboard?
I've been down that road recently and always check for updates to the chipset drivers, especially the USB. I don't even rely on the motherboard maker to have the latest. I track back to the chip makers, Intel, Reaktek and so on.
I have never had any need for heavyweight wifi, but if I did I would have put in a PCI-e card to cover that.
