Rattl3r
Jul 22, 2020Initiate
Having memory leak with A7000 driver version 1.0.0.11
Hi I am currently having some major driver leak errors originating from the A7000 drivers version 1.0.0.11. I had seen in a previous thread someone was having similar issues being reported by poolmon...
chid
Jul 23, 2020Aspirant
yeah I've had the same issue. I usually keep my PC on and has leaked ~2GB in about 3 days. It's been up to ~5GB when I've had it on for weeks.
I know it is because I can uninstall the A7000 driver and the memory is freed.
Blanca_O
Jul 29, 2020NETGEAR Employee Retired
Welcome to NETGEAR Community!
Do you have NETGEAR Genie installed?
Have you tried installing the stand-alone driver version?
Blanca
Community Team
- Rattl3rJul 29, 2020InitiateYes I have tried both ways with all 3 driver versions avaliable on your support tab for the A7000
- Blanca_OJul 29, 2020NETGEAR Employee Retired
- daikessenOct 07, 2020Aspirant
Hello!
I am having a similar issue / memory leak with 1.0.0.15, and was considering testing 1.0.0.11 until running into this thread.
I am just curious, is there a beta driver or other recommendation to resolve this issue?
Thank you!
- dale5351Aug 02, 2021Aspirant
I have also discovered that the A7000 driver is causing a memory leak. I tried rolling back to 11 version, but both 11 and 15 have the same problem.
Would appreciate any help that can be had.
- dale5351Sep 02, 2021Aspirant
After months of fighting this memory leak, using both versions 11 and 15, I discovered and installed version 10. Now I have not had a memory leak problem for several days.
