Rattl3r
Jul 22, 2020Initiate
Having memory leak with A7000 driver version 1.0.0.11
Hi I am currently having some major driver leak errors originating from the A7000 drivers version 1.0.0.11. I had seen in a previous thread someone was having similar issues being reported by poolmon...
Rattl3r
Jul 29, 2020Initiate
Yes I have tried both ways with all 3 driver versions avaliable on your support tab for the A7000
Blanca_O
Jul 29, 2020NETGEAR Employee Retired
- daikessenOct 07, 2020Aspirant
Hello!
I am having a similar issue / memory leak with 1.0.0.15, and was considering testing 1.0.0.11 until running into this thread.
I am just curious, is there a beta driver or other recommendation to resolve this issue?
Thank you!
- d_boneNov 23, 2020Aspirant
Hello, I've been dealing with a WIndows 10 memory leak for months, and recently isolated my A7000 driver as the culprit.
As stated by others, poolmon.exe showed me that driver tag "A700" was causing the leak. I can disable and then re-enable the adapter in Device Manager, which temporarily clears the memory leak before it steadily builds back up over time, usually about a gig or two per day.
I have tried all three currently available driver versions (1.0.0.10, 1.0.0.11, 1.0.0.15), both standalone and with Genie, but the memory leak persists.
If you have a legacy version somewhere prior to these three most recent bugged versions it would be much appreciated!
- DoggysApr 05, 2021Aspirant
Hello,
I have the exact same issue, cheked with poolmon:
Memory: 8347392K Avail: 1633064K PageFlts: 21380 InRam Krnl: 9896K P:344952K
Commit:11921780K Limit:16736000K Peak:14562284K Pool N:1819740K P:403264K
System pool information
Tag Type Allocs Frees Diff Bytes Per AllocA700 Nonp 15219096 ( 567) 8720668 ( 270) 6498428 1351786176 ( 61776) 208
Is there any ather driver to test?
Regards
