NEHC02's avatar
NEHC02
Initiate
Dec 11, 2021
help with readyshare mac monterey
Hi,
Please help me install Readyshare for my macbook pro monterey. I downloaded and installed readyshare for mac 3.1. After I reboot the laptop, netgear usb control center said installation incomplete. What am i doing wrong?
Thank you
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Can you fill us in on what you are trying to setup?
    You have posted in the section for WiFi Adapters but your "footer" says you have an R7800 router.
    What do  you want to install? A printer to share on your network? USB storage connected to the router?
    If this is a printer, have you set it up in the browser graphical user interface (GUI)? Is the printer installed on all the devices you want to connect to the network printer?
