nijat1122
Apr 17, 2023Follower
How can I check if my website is being blocked by the Netgear RBK752 router or any other device!
As a website owner, I'm concerned that my website might be blocked by my Netgear RBK752 router or other network devices. How can I check if this is the case? Are there any tools or methods that can h...
michaelkenward
Apr 18, 2023Guru - Experienced User
If this is a genuine query rather than then link spam – see the embedded URL – it is in the wrong place.
This section is about USB adapters for wifi.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
