yhc
Jun 07, 2026Aspirant
How can I connect the 6GHz Wi-Fi on channel 1 (5955 MHz) using the AXE3000 (A8000)?
Hi Netgear Team and Community, Thank you for your excellent products and support. I am currently using the AXE3000 (A8000) WiFi 6E USB adapter and would like to ask for your assistance with a...
CrimpOn
Jun 07, 2026Guru - Experienced User
Is there a reason that channel 1 must be used? When WiFi adapters and access points specify a channel, that is only to indicate which frequency will be used for management frames. When attempting to transmit actual data, a group of channels is used at the same time. The most expedient solution is to change the WiFi system to use a channel other than channel 1.
If the adapter is connected to a Windows computer, it might be interesting to open the network management control panel and look at Properties of the WiFi adapter and see what sort of options are provided. There may be a setting that restricts channel usage.
This is one of the WiFi adapters on my Windows computer. The A8000 may have different properties.
- yhcJun 07, 2026Aspirant
Thanks for your feedback.
The reason for focusing on Channel 1 is that another Wi-Fi 6E adapter (TP-Link AXE5400) can successfully detect and connect to the same 6 GHz SSID when the AP is configured to use Channel 1 (5955 MHz), while the AXE3000 (A8000) cannot.
