yhc
Jun 07, 2026Aspirant
How can I connect the 6GHz Wi-Fi on channel 1 (5955 MHz) using the AXE3000 (A8000)?
Hi Netgear Team and Community, Thank you for your excellent products and support. I am currently using the AXE3000 (A8000) WiFi 6E USB adapter and would like to ask for your assistance with a...
muhammadammar23
Since the A8000 works on Channel 9 but not Channel 1, the issue is likely related to driver support or regional channel restrictions. Make sure you're using the latest driver and verify your region settings. If other 6 GHz adapters can connect on Channel 1, the router is probably not the problem.
yhc
Thanks for your feedback!
The driver version currently used is:
A8000 Software Version 1.0.0.125 for Windows
https://kb.netgear.com/000066043/A8000-Software-Version-1-0-0-125-Windows
Regarding the region settings, could you please advise how I can verify the current regulatory domain configuration on the AXE3000 (A8000)? Also, what would be the correct or recommended setting for 6 GHz Channel 1 (5955 MHz) support?
Thank you!
