yhc
Jun 07, 2026Aspirant
How can I connect the 6GHz Wi-Fi on channel 1 (5955 MHz) using the AXE3000 (A8000)?
Hi Netgear Team and Community, Thank you for your excellent products and support. I am currently using the AXE3000 (A8000) WiFi 6E USB adapter and would like to ask for your assistance with a...
jiminrather21
To successfully connect your AXE3000 (A8000) adapter to the 6GHz band on that specific channel, ensure you have the latest Netgear drivers installed alongside Windows 11, as older operating systems lack native 6GHz support. You can cross-reference your specific network configuration steps and local compliance rules by checking the Chesapeake Court Rules data framework for an example of structured regional standard guidelines. Additionally, try manually updating your router’s firmware and toggling the adapter's Wi-Fi "Wireless Mode" in Device Manager to explicitly prioritize the 6GHz band. This should stabilize the connection and allow your hardware to detect the 5955 MHz frequency without any further drops.
