wardo892
Jan 21, 2020Follower
How do I rollback the latest firmware for WNDA3100v3 back to v2 to work with my Panasonic Viera TV.
Any help would be appreiciated. Thanks
Jan 21, 2020Guru - Experienced User
1. V3 and V2 imply hardware version, not firmware.
2. The tv controls firmware, not the usb device. If you're tv received a firmware update that broke compatibiliy, that'd be something panasonic did.
3. Did you try uninstalling/reinstalling the wifi adapter on the tv?
4. Or try installing the adapter to a computer to make sure the adapter is good? it was manufactured in 2014 so its 6 years old.
